EX3500 Version
The EX3500 switch Version screen lists hardware and switch software version information utilized for the selected EX3500 switch. Use this information when reporting any issues to Support or when assessing whether an update would improve switch performance.
To view EX3500 switch version information:
  • Refer to the Unit ID and Serial Number items to assess the switch numeric identifier and serial number.
  • The Hardware Version lists hardware version of the EX3500 switch main board.
  • Refer to the EPLD Version to check the EPLD (erasable programmable logic device) comprising an array of PLD (programmable logic devices) that do not come pre-connected with the switch.
  • The Number of Ports field lists built-in port utilization. The EX3524 and EX3548 are Gigabit Ethernet Layer 2 switches with either 24 or 48 10/100/1000-BASE-T ports, and four SFP (Small Form Factor Pluggable) transceiver slots for fiber connectivity.
  • Refer to the Main Power Status item to assess the status of the internal power supply.
  • Refer to the Role table item to review the switch's current defined network role (master or slave).
  • The Loader Version item displays the version number of the switch loader code.
  • The Operation Code Version lists the version number of the switch's runtime code.
  • The Adopted Version lists the version of the management agent used by the switch to adopt to a WiNG controller.
  • The Linux Version lists the version of the Linux operating system utilized on the switch.
Periodically select Refresh to update the screen to its latest information.
