The following updates have been made in Revision AB of this guide.
| Updates | Description |
| GRE Tunnel Configuration | The devices that support GRE Tunneling and the Maximum GRE Tunnels Supported have been corrected. |
The following changes and updates have been made in Revision AA of this guide.
| Update | Description |
| About this Guide | This chapter has been removed. Hardware descriptions and specifications have been relocated to the Appendices in this Guide. |
| WiNG 7 Operating System Overview | Hardware descriptions and specifications contained in this chapter have been relocated to the Appendices in this Guide. |
| Radio settings configuration adds support for 6 GHz radio 3 | |
| Client Bridge Settings | Client bridge configuration is supported for 6 GHz radio 3 |
| GRE Tunnel Configuration | Support for configuring up to 1000 GRE tunnels added on NX7500, NX9500, NX9600 and NX9610 platforms |
| Meshpoint configuration is supported for 6 GHz radio 3 | |
| Configure WLAN Client Settings | Corrected documented default setting for the Radio Resource Measurement parameter: the correct default setting is enabled. |
| Configuring Smart RF Channel & Power Settings | Smart RF channel and power configuration are supported for 6 GHz radio 3 |
| Configuring a MeshConnex Policy | MeshConnex policy configuration is supported for 6 GHz radio 3 |
