| Traffic Type |
Use the drop-down menu to define
the traffic type for which the Storm Control configuration
applies. Options include ARP, Broadcast, Multicast and
Unicast. |
| Interface Type |
the interface for which the Storm Control configuration is
applied. Only the specified interface uses the defined
filtering criteria. Options include Ethernet, WLAN and Port
Channel. |
| Interface Name |
Use the drop-down menu to refine
the interface selection to a specific WLAN or physical port.
This helps with threshold configuration for potentially
impacted interfaces. |
| Packets per Second |
Select the check box to activate
the spinner control used for specifying the packets per
second threshold for activating the Storm Control
mechanism. |
