To add a new Management Access policy, or edit an existing configuration:
Select Configuration → Management →Management Policy
to display the main Management
Policy screen and the Management Browser.
To modify
an existing policy, select Management Browser > Edit.
To add a
new policy, click Add on the bottom right-hand side of the
Management screen.
Name the new policy to enable the Access Control,
SNMP, SNMP Traps and
Administrators tabs and define the policy
configuration.
The name cannot exceed 32 characters.
Click OK to commit the new policy name.
Once the new name is defined, the screen's tabs become enabled, with the
contents of the Administrators tab displayed by default. Refer
to the following to define the configuration of the new Management Access policy:
Use the
Administrators tab to create
specific users, assign them permissions to specific
protocols and set specific administrative roles for the
network.
Use the
Access Control tab to
enable/disable specific protocols and interfaces. Again,
this kind of access control is not meant to function as
an ACL, but rather as a means to enable/disable specific
protocols (HTTP, HTTPS, Telnet etc.) for each Management
Access policy.
Use the
SNMP Traps tab to enable trap
generation for the policy and define trap receiver
configurations.
For deployment considerations and recommendations impacting a controller or service
platform‘s Management Access policy configuration, refer to Management Access Deployment Considerations.
