AP Humidity Sensor
To view an AP 8132 model access point‘s deployment area humidity:
  1. Select the Statistics menu from the Web UI.
  2. Expand the System node from the navigation pane (on the left-hand side of the screen). The System node expands to display the RF Domains created within the managed network.
  3. Expand an RF Domain node, and select one of it's connected access points. The access point's statistics menu displays in the right-hand side of the screen, with the Health tab selected by default.
  4. Expand the Environment menu.
  5. Select the Humidity tab.
    The Statistics > AP 8132 > Environment > Humidity tab displays.
  6. Refer to the Humidity table to assess the sensor's detected humidity fluctuations within the AP 8132‘s immediate deployment area.
    Humidity is measured in percentage. The table displays the Current Humidity (percent) and the 20 Minute Average Humidity (percent). Compare these two items to determine whether the AP 8132‘s deployment location remains consistently humid (often a by-product of temperature).
  7. Refer to the Humidity Trend Over Last Hour graph to assess the fluctuation in humidity over the last hour. Use this graph in combination with the Temperature and Motions graphs (in particular) to assess the deployment area‘s activity levels.
  8. Refer to the Humidity Trend Over Last Day graph to assess whether deployment area humidity is consistent across specific hours of the day. Use this information to help determine whether the AP 8132 can be upgraded or powered off during specific hours of the day.
  9. Select Refresh at any time to update the screen‘s statistics counters to their latest values.
