Proxy ARP is disabled by default.
Access global configuration
mode.
device# configure terminal
Access the interface on which you are enabling Proxy ARP.
device(config)# interface ethernet 0/1
Enable Proxy ARP.
device(conf-if-eth-0/1)# ip proxy-arp
The following example summarizes the commands in this
procedure.
