Modifying SPF timers
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the ipv6 router ospf command to enter OSPFv3 router configuration mode and enable OSPFv3 globally.
    device(config)# ipv6 router ospf
  3. Enter the timers command with the spf parameter.
    device(config-ipv6-router-ospf-vrf-default-vrf)# timers spf 1 5
    The SPF delay is changed to 1 second and the SPF hold time is changed to 5 seconds.
The following example changes the SPF delay and hold time.
