BGP Peer Flap dampening is used to prevent unstable BGP peers from bringing down the network. Unstable peers cause a change in the routing state that requires forwarding entries to be added or removed from the forwarding table.
Adding or removing entries from the forwarding table is computationally intensive and could result in the router not being able to maintain its BGP or IBGP sessions due to it being busy. This could, sometimes, result in the router becoming unresponsive.
When a router becomes unresponsive, it can cause an increase in the network which may result in unexpected behavior and further disruptions. In some cases, it could also result in a state of stable oscillation, which has to be avoided and is harder to recover.
The optional session attribute suggested in RFC-4271-section 8.1.1, DampPeerOscillations indicates that the BGP connection is using logic that damps BGP peer oscillations in the Idle State.
A stable BGP Peer will be in the Established
state. When
there is a flap in the peer session, the peer is considered to be unstable and
placed in the Idle
state. Whenever the peer is placed in the
Idle
state, the Idle-Hold
timer is
started.
If this is the first time the peer is placed in the Idle
state, the
Idle-Hold
timer
is initialized with the value specified in the Delay-Hold
configuration, else, a time penalty is added to the Idle-Hold
timer. This penalty time is defined in the Penalty
configuration.
For every subsequent flap, the Penalty
value is added to the
Idle-Hold
time till the Idle-Hold
timer value
reached the value specified in the Maximum-Penalty
upper limit
value. When the Idle-Hold
timer reaches or exceeds the
Maximum-Penalty
value, the Penalty
value will
not be added to the Idle-Hold
for subsequent flaps.
When the peer's status changes from Idle
to
Established
, the Stability-Interval
timer
starts. If the BGP peer remains stable (error-free) till the expiry of the
Stability-Interval
timer, the Idle-Hold
timer
is reduced by the Penalty
value. This is done every time the peer
is stable for the Stability-Interval
period till the
Idle-Hold
timer reaches zero (0).
If the value of the Idle-Hold
timer is lesser than the
Penalty
value, i.e., reducing the Penalty
value from the Idle-Hold
value causes the Idle-Hold
value to go below zero (0), then the Idle-Hold
value is reduced by
value.
