Consider the following when you configure the
DHCPv4 relay gateway address.
- If the relay gateway address is
configured, but no IP address is configured on the interface, the DHCP relay
agent does not relay the requests.
- When the relay gateway address matches an IP address that is configured on
the interface, it is used to stamp the request.
- When the relay gateway address does
not match the IP addresses configured on the interface, the DHCP relay agent
uses the default value, which is the lowest-numbered IP address configured
on the interface.
- Virtual IP addresses or local
subnet broadcast addresses must not be used as the relay gateway address.
- Any primary or secondary IP address
configured on the interface can be used as the relay gateway address.
