GR is mutually exclusive to NSR.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router ospf command to enter OSPF router configuration mode and enable OSPFv2 globally.
    device(config)# router ospf
  3. Enter the graceful restart command to re-enable GR on the device.
    device(config-router-ospf-vrf-default-vrf)# graceful-restart
  4. Enter the graceful restart command with the restart-time parameter and specify a value to change the maximum restart wait time from the default value of 120 seconds.
    device(config-router-ospf-vrf-default-vrf)# graceful-restart restart-time 240
The following example re-enables GR and changes the maximum restart wait time from the default value of 120 seconds to 240 seconds.
