When an additional-paths capability is configured for a BGP address family, you can disable the capability for a specific neighbor or peer group under the address family.
  1. From privileged EXEC mode, enter global configuration mode.
    device# configure terminal
  2. Enable BGP routing.
    device(config)# router bgp
  3. Enter configuration mode for the IPv4 unicast address family.
    device(config-bgp)# address-family ipv4 unicast
  4. Disable the additional-paths capability for a specific peer device.
    device(config-bgp-ipv4u)# neighbor 10.12.12.12 additional-paths disable
    This example disables the additional-paths capability for peer device 10.12.12.12
    When you run this command for an address-family level on which the additional-paths capability is not configured, an error message is displayed.
  5. Restart the BGP session to activate the new additional-paths capability configuration.
This example re-enables the additional-paths capability on the specific neighbor 10.12.12.12 in the IPv4 unicast address family.
device(config-bgp-ipv4u)# no neighbor 10.12.12.12 additional-paths disable
