The following steps must be performed to migrate from a non-MT environment to an MT environment.
Assume that the entire network is not an IPv6 IS-IS MT environment, and ensure that all the routes are correct.
Use the
multi-topology command with the
transition parameter to enable transition mode on each router one by one, and ensure that all the routes are correct.
After all the routers are in transition mode, use the
no multi-topology command with the
transition parameter to disable transition mode on each router one by one. Ensure that all the routes are correct.
Change the topology to make IPv4 and IPv6 different.
