Resilient Hashing is available for default VRF as well as user created VRFs. To configure Resilient Hashing on default VRF:
conf term
command.
SLX# conf term SLX(config)#
resilient-hash
command to configure.
SLX (config)# resilient-hash ? Possible completions: ecmp Resilient hash ECMP max-path Resilient hash max path (8|16|64) SLX (config)# resilient-hash ecmp ? Possible completions: enable Enable resilient hash ECMP SLX (config)# resilient-hash ecmp enable
max-path
value.
The default max-path
value is 8. You can choose to use 8, 16, or 64 paths.
SLX (config)# resilient-hash ? Possible completions: ecmp Resilient hash ECMP max-path Resilient hash max path (8|16|64) SLX (config)# resilient-hash max-path 8 SLX (config)#
show ip route system-summary
command.
SLX # show ip route system-summary System Route Count: 10 Max routes: 358400 (Route limit not exceeded) System Nexthop Count: 2 Max nexthops: 4000 (Nexthop limit not exceeded) One Path Nexthop Count: 1 Max One Path Nexthops: 48000 RH Flowset Entries: 2816 Max 32768 (Flowset limit not exceeded) VRF-Name: default-vrf Route count: 0 Max routes: Not Set (Route limit not exceeded) 0 connected, 0 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host Resilient Hashing (Flowset Sz: 128, Max RH Paths: 8, RH Nexthops: 12) VRF-Name: mgmt-vrf Route count: 3 Max routes: Not Set (Route limit not exceeded) 1 connected, 1 static, 0 OSPF, 0 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host VRF-Name: vrf2 Route count: 7 Max routes: Not Set (Route limit not exceeded) 2 connected, 2 static, 0 OSPF, 1 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host Resilient Hashing (Flowset Sz: 128, Max RH Paths: 16, RH Nexthops: 10) VRF-Name: vrf3 Route count: 7 Max routes: Not Set (Route limit not exceeded) 2 connected, 2 static, 0 OSPF, 1 BGP, 0 ISIS, 0 unnumbered, 0 EVPN Host SLX #
