Important
This procedure requires a system reload to activate the profile configuration.device# configure terminal
device(config)# hardware
device(config-hardware)# profile tcam border-routing
device(config-hardware)# profile counters counter-profile-1
device(config-hardware)# profile counters counter-profile-4
device(config-hardware)# exit
device# reload system
The following example summarizes the commands in this procedure.
device# configure terminal device(config)# hardware device(config-hardware)# profile tcam border-routing device(config-hardware)# profile counters counter-profile-1 device(config-hardware)# exit device# reload system
