Important
Dynamic inter-VRF route leaking is a feature that should be deployed only by an advanced user.
Note the following limitations and considerations for route leaking:
- Leaked routes will not be leaked again.
- Control plane protocols cannot run on leaked routes.
- Leaking the same prefix across VRFs is not supported. That is, a given prefix can be present in multiple VRFs, but it should not be leaked from one VRF to another. The behavior in such a case will be inconsistent.
