Changing the metric style
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
  3. Enter the address-family ipv4 unicast command to enable ISIS address-family IPv4 unicast configuration mode.
    device(config-isis-router)# address-family ipv4 unicast
  4. Enter the metric-style wide command to enable the wide metric type for Level 2 packets for the IS-IS IPv4 unicast address-family.
    device(config-router-isis-ipv4u)# metric-style wide level-2
The following example enables the wide metric type for Level 2 packets for the IS-IS IPv4 unicast address-family.
