Enable BGP4 Route Dampening
You can enable the default dampening parameters or specify the values you want.
  1. Access global configuration mode.
    device# configure terminal
  2. Access BGP configuration mode.
    device(config)# router bgp
  3. Access address-family ipv4 unicast configuration mode.
    device(config-bgp-router)# address-family ipv4 unicast
  4. Enable the default dampening parameter values.
    device(config-bgp-ipv4u)# dampening
This example sets the half-life parameter to 20, the reuse parameter to 200, the suppress parameter to 2500, and the max-suppress-time parameter to 40.
device(config-bgp-ipv4u)# dampening 20 200 2500 40
