By default, BGP4+ balances traffic across one path. You can use the multipath feature to enable load-balancing across different BGP4+ paths.
BGP4+ selects only one best path for each IPv6 prefix it receives before installing it in the IP routing table. For load balancing across different paths, use the maximum-paths command to enable BGP4+ multipath.
You can select iGP paths, eBGP paths, or a combination of both.
The following attributes of parallel paths must match for them to be considered for multipathing:
