You can create a static ARP entry for a device that is not yet connected to the network or to prevent an entry from aging out.
  1. Access global configuration mode.
    device# configure terminal
  2. Access VRF configuration mode.
    device(config)# vrf test
  3. Specify the address family.
    device(config-vrf-test)# address-family ipv4 unicast
  4. Create the static ARP entry.
    device(vrf-test-ipv4-unicast)# arp 10.6.6.7 0001.0001.0001 interface ethernet 0/1
    This example creates a static ARP entry for IP address 10.6.6.7 and associates it with MAC address 0001.0001.0001 and Ethernet interface 0/1.
The following example summarizes the commands in this procedure.
