Configuring BGP4+ graceful restart
The graceful restart (GR) feature can be configured on a routing device, providing it with the capability to inform its neighbors when it is performing a restart.
High availability (HA) requires GR to be enabled.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router bgp command to enable BGP routing.
    device(config)# router bgp
  3. Enter the local-as command to configure the autonomous system number (ASN) in which your device resides.
    device(config-bgp-router)# local-as 1000
  4. Enter the neighbor remote-as command, specifying an IPv6 address, to specify the autonomous system ASN in which the remote neighbor resides.
    device(config-bgp-router)# neighbor 1000::1 remote-as 2
  5. Enter the address-family ipv6 unicast command to enter IPv6 address family configuration mode.
    device(config-bgp-router)# address-family ipv6 unicast
  6. Enter the neighbor activate command to add a neighbor.
    device(config-bgp-ipv6u)# neighbor 1000::1 activate
  7. Enter the graceful-restart command to enable the graceful restart feature.
    device(config-bgp-ipv6u)# graceful-restart
  8. Do any of the following:
    • Enter the graceful-restart command using the purge-time keyword to overwrite the default purge-time value.
      device(config-bgp-ipv6u)# graceful-restart purge-time 300
    • Enter the graceful-restart command using the restart-time keyword to overwrite the default restart-time advertised to graceful restart-capable neighbors.
      device(config-bgp-ipv6u)# graceful-restart restart-time 180
    • Enter the graceful-restart command using the stale-routes-time keyword to overwrite the default amount of time that a helper device will wait for an EOR message from a peer.
      device(config-bgp-ipv6u)# graceful-restart stale-routes-time 100
The following example enables the graceful restart feature.
The following example enables the graceful restart feature and sets the purge time to 300 seconds, overwriting the default value.
The following example enables the graceful restart feature and sets the restart time to 180 seconds, overwriting the default value.
The following example enables the graceful restart feature and sets the stale-routes time to 100 seconds, overwriting the default value.
What to do next
Use the clear ipv6 bgp neighbor command with the all parameter for the changes to the graceful restart parameters to take effect immediately.
