VRRP-Ev3 traffic can be load-balanced using short-path forwarding on the backup devices.
Before configuring VRRP-Ev3 load-balancing, VRRP-Ev3 must be configured on all devices in the VRRP-Ev3 session.
Perform this task on all backup VRRP-Ev3 Layer 3 devices to allow load sharing within an IPv6 VRRP extended group.
  1. Use the configure terminal command to enter global configuration mode.
    device# configure terminal
  2. Globally enable VRRP-Ev3.
    device(config)# ipv6 protocol vrrp-extended
  3. Enter the interface ve command with an associated VLAN number.
    device(config)# interface ve 2019
    In this example, virtual Ethernet (ve) configuration mode is entered and the interface is assigned with a VLAN number of 2019.
  4. Enter an IPv6 address for the interface using the ipv6 address command.
    device(config-ve-2019)# ipv6 address 2001:2019:8192::122/64
  5. Enter the ipv6 vrrp-extended-group command with a number to assign a VRRP-E group to the device.
    device(config-ve-2018)# ipv6 vrrp-extended-group 19
    In this example, VRRP-Ev3 group configuration mode is entered.
  6. Enter the short-path-forwarding command with a revert-priority value to configure the backup VRRP-E as an alternate path with a specified priority.
    device(config-vrrp-extended-group-19)# short-path-forwarding revert-priority 50
    When the backup device priority is higher than the configured revert-priority value, the backup router is able to perform short-path forwarding. If the backup priority is lower than the revert priority, short-path forwarding is disabled.
In the following example, short-path forwarding is configured on a backup VRRP-Ev3 device and a revert priority threshold is configured. If the backup device priority falls below this threshold, short-path forwarding is disabled.
device# configure
device(config-ve-2019)# ipv6 vrrp-extended-group 19
