The IS-IS IPv4 unicast address family allows you to configure IPv4 IS-IS unicast settings that are separate and distinct from IPv6 IS-IS unicast settings. The following task enables ISIS IPv4 address family unicast configuration mode where a variety of IS-IS features can be configured.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
  3. Enter the address-family ipv4 unicast command to enable ISIS address-family IPv4 unicast configuration mode.
    device(config-isis-router)# address-family ipv4 unicast
The following example enables ISIS address-family IPv4 unicast configuration mode.
device(config-router-isis-ipv4u)#
