You can configure the intervals that a
		device waits to send (transmit) or receive control packets from Bidirectional Forwarding
		Detection (BFD) peers.
BFD is enabled by default on configured
			Layer 3 interfaces (IPv4 or IPv6). Take the following steps to configure the BFD session
			parameters.
				Access global configuration
					mode.
device# configure terminal
				Access interface configuration
					mode.
device(config)# interface ethernet 1/4
				Specify the transmit time in milliseconds (ms), the receive time in ms, and the
					multiplier value that determines the number of consecutive control packets that
					must be missed before the connection to a peer is considered non-operational.
					device(conf-if-eth-1/4)# bfd interval 100 min-rx 100 multiplier 10
				This example specifies a transmit interval of 100 ms, the min-rx keyword followed by a receive interval
					of 100 ms, and the multiplier value of 10, which indicates that 10 consecutive
					packets must be missed before the connection to the peer is considered
					non-operational.
		This example configures BFD session parameters
				on a VE interface.
device(config)# interface ve 24
device(config-if-ve-24)# bfd interval 140 min-rx 125 multiplier 44
