You can configure a static route with a tag that can be referenced in a route map.
Enable IPv6 on at least one interface by configuring an IPv6 address or explicitly enabling IPv6 on that interface.
  1. Access global configuration mode.
    device# configure terminal
  2. Enter the destination IP address, next-hop address, the tag keyword, and a tag number.
    device(config)# ipv6 route 2001:DB8::0/64 2001:DB8:0:ee44::1 tag 3
    The tag "3" in this example can be used in a route map.
