Enable Conversational ND
Conversational ND can reduce the number of cached ND entries, optimizing usage of hardware resources.
  1. Access global configuration mode.
    device# configure terminal
  2. Specify an aging-time value other than the default 300 seconds.
    device(config)# host-table aging-time conversational 600
    This example sets the aging-time value to 600 seconds.
  3. Enable conversational ND.
    device(config)# host-table aging-mode conversational
The following example summarizes the commands in this procedure.
