Configuring an NSSA
OSPFv2 areas can be defined as NSSA areas with modifiable parameters.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router ospf command to enter OSPF router configuration mode and enable OSPFv2 on the device.
    device(config)# router ospf
  3. Enter the area nssa command and specify an area address and a cost.
    device(config-router-ospf-vrf-default-vrf)# area 10.1.1.1 nssa 1
    Area 10.1.1.1 is defined as an NSSA.
The following example configures OSPF area 10.1.1.1 as an NSSA.
