You can configure the intervals that a
		device waits to send (transmit) or receive control packets from Bidirectional Forwarding
		Detection (BFD) peers. You can also configure the interval after which routes are withdrawn
		when a BFD session is down.
				Access global configuration
					mode.
					device# configure terminal
				Access BGP configuration mode.
					device(config)# router bgp
				(Multihop sessions only) Specify
					the transmit time, the receive time, and the number of consecutive control
					packets that must be missed before the connection to a peer is considered
					non-operational.
					device(config-bgp-router)# bfd interval 140 min-rx 125 multiplier 44
				This example specifies a transmit interval of 140 ms, the
min-rx keyword followed by a receive interval
					of 125 ms, and the multiplier value of 44, which indicates that 44 consecutive
					packets must be missed before the connection to the peer is considered
					non-operational.
For
						single-hop sessions, run the
bfd interval command at the
						interface level.
				Specify the interval after which
					BGP routes are withdrawn after a BFD session is declared down.
					device(config-bgp-router)# bfd holdover-interval 15
				This example specifies a holdover interval of 15 seconds.
