IS-IS can be enabled for a specified interface for a device. Several commands can then be accessed that allow the configuration of IS-IS on the specified interface. This task enables IS-IS routing for an interface Ethernet.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the interface ethernet command and specify an interface.
    device(config)# interface ethernet 1/2
  3. Enter the ip router isis command to enable IS-IS for the interface.
    device(conf-if-eth-1/2)# ip router isis
The following example enables IS-IS routing for an interface Ethernet.
