Redistribute Routes into BGP4
You can advertise routes into BGP4 by redistributing static, connected, ISIS, or OSPF routes.
Routes learned through BGP4 can be redistributed into OSPF or IS-IS. You can specify an optional route-map, which is consulted before routes are added to BGP. Management routes are not redistributed.
  1. Access global configuration mode.
    device# configure terminal
  2. Access BGP configuration mode.
    device(config)# router bgp
  3. Access BGP IPv4 address family unicast configuration mode.
    device(config-bgp-router)# address-family ipv4 unicast
  4. Redistribute connected routes.
    device(config-bgp-ipv4u)# redistribute connected
This example redistributes IS-IS routes with level 1 packets.
device(config-bgp-ipv4u)# redistribute isis level-1
This example redistributes static routes with a metric of 200.
device(config-bgp-ipv4u)# redistribute static metric 200
This example redistributes OSPF external type 1 routes with a metric of 200.
device(config-bgp-ipv4u)# redistribute ospf match external1 metric 200
