You can set a BGP route-flap dampening penalty in a route-map instance..
				Access global configuration
					mode.
					device# configure terminal
				Create a route map instance and
					allow a matching pattern.
					device(config)# route-map myroutemap permit 1
 This example shows the route-map command, the route map
					name (myroutemap), the permit keyword, and the matching
					pattern of 1.
				Specify the dampening penalty
					for the route-map instance.
					device(config-route-map-myroutemap/permit/1)# set dampening 20
 This example specifies a penalty of 20.
