IS-IS Point-to-Point over Ethernet can be configured so that devices that are several hops away can form an IS-IS adjacency. The following task configures two devices, Device A and Device B, for IS-IS point-to-point over Ethernet.
  1. On Device A, enter the configure terminal command to access global configuration mode.
    deviceA# configure terminal
  2. Enter the interface ethernet command and specify an interface.
    deviceA(config)# interface ethernet 1/2
  3. Enter the ip router isis command to enable IS-IS for the interface.
    deviceA(conf-if-eth-1/2)# ip router isis
  4. Enter the ip address command and specify an IP address and mask to configure a primary IP address for the interface.
    deviceA(conf-if-eth-1/2)# ip address 10.10.1.1/31
  5. Enter the isis point-to-point command to configure IS-IS point-to-point for the Ethernet interface.
    deviceA(conf-if-eth-1/2)# isis point-to-point
  6. On Device B, enter the configure terminal command to access global configuration mode.
    deviceB# configure terminal
  7. Enter the interface ethernet command and specify an interface.
    deviceB(config)# interface ethernet 2/1
  8. Enter the ip router isis command to enable IS-IS for the interface.
    deviceB(conf-if-eth-2/1)# ip router isis
  9. Enter the ip address command and specify an IP address and mask to configure a primary IP address for the interface.
    deviceB(conf-if-eth-2/1)# ip address 10.10.1.2/31
  10. Enter the isis point-to-point command to configure IS-IS point-to-point for the Ethernet interface.
    deviceB(conf-if-eth-2/1)# isis point-to-point
The following example configures two devices, Device A and Device B, for IS-IS point-to-point over Ethernet.
