Enabling the alternate VRRPv2-style checksum in a VRRPv3 IPv4 session for compatibility with third-party network devices.
VRRPv3 uses the v3 checksum computation method by default for both IPv4 and IPv6 sessions on this device. Third-party devices may only have a VRRPv2-style checksum computation available for a VRRPv3 IPv4 session. The use-v2-checksum command is entered in interface configuration mode.
  1. Enter the configure terminal command to enter global configuration mode.
    device# configure terminal
  2. To enable VRRP globally enter the protocol vrrp command.
    device(config)# protocol vrrp
  3. Enter the interface ve command with an associated VLAN number.
    device(config)# interface ve 2018
  4. To assign an IPv4 VRRPv3 group to the device use the vrrp-group command with a group number and version 3.
    device(config-ve-2018)# vrrp-group 10 version 3
  5. To enable v2 checksum computation method in an IPv4 VRRPv3 session, use the use-v2-checksum command in the VRRP group configuration mode.
    device(config-vrrp-group-10)# use-v2-checksum
The following example shows the v2 checksum computation method enabled for an VRRPv3 IPv4 session on a device.
