The show ipv6 ospf command and its variations can be used to display information about OSPFv3 configurations.
device# show ipv6 ospf OSPFv3 Process number 0 with Router ID 0xc0a80001(192.168.0.1) Running 0 days 0 hours 49 minutes 2 seconds Number of AS scoped LSAs is 1 Sum of AS scoped LSAs Checksum is 0000d72f External LSA Limit is 250000 Database Overflow Interval is 10 Database Overflow State is NOT OVERFLOWED Route calculation executed 10 times Pending outgoing LSA count 0 Authentication key rollover interval 300 seconds Number of areas in this router is 3 Router is operating as ABR Router is operating as ASBR, Redistribute: STATIC High Priority Message Queue Full count: 0 BFD is disabled, BFD HoldoverInterval: 0 Graceful restart helper is enabled, strict lsa checking is disabled Nonstop Routing is enabled Administrative Distance - External Routes: 110 - Intra Area Routes: 110 - Inter Area Routes: 110 Maximum Paths: 8
device# show ipv6 ospf summary Total number of IPv6 OSPF instances: 1 Seq Instance Intfs Nbrs Nbrs-Full LSAs Routes 1 default-vrf 3 1 1 19 3
device# show ipv6 ospf summary all-vrfs total
         IPv6 OSPF Summary Total
Number of instances: 1024
Number of interfaces: 2048
Number of neighbors: 2048
Number of neighbors  in FULL state: 2048
Number of LSAs: 76786
Number of Routes: 67570
QCount is the LSA retransmission list count. The number displays the number of LSAs that are waiting for acknowledgements.device# show ipv6 ospf neighbor Total number of neighbors in all states: 1 Number of neighbors in state Full : 1 RouterID Pri State DR BDR Interface State QCount 192.168.0.2 1 Full 192.168.0.1 192.168.0.2 Eth 0/1 DR 0
device# show ipv6 ospf neighbor detail
                Option: 00-00-00    Timer: 683
BFD State: NONE, BFD HoldoverInterval(sec):Configured: 0 Current: 0
		  device# show ipv6 ospf memory vrf vrf_1 Total Dynamic Memory Allocated for this instance : 87046288 bytes global shared memory pool for all instances Memory Type Size Allocated Max-alloc Alloc-Fails MTYPE_OSPF6_AREA 1100 1024 1065 0 MTYPE_OSPF6_AREA_RANGE 52 0 16 0 MTYPE_OSPF6_SUMMARY_ADDRE 36 0 16 0 MTYPE_OSPF6_IF 396 2048 2625 0 MTYPE_OSPF6_NEIGHBOR 24916 2048 2098 0 MTYPE_OSPF6_ROUTE_NODE 36 71666 72415 0 MTYPE_OSPF6_ROUTE_INFO 52 71666 80537 0 MTYPE_OSPF6_PREFIX 24 0 16 0 MTYPE_OSPF6_LSA 252 76787 133135 0 MTYPE_OSPF6_VERTEX 196 5120 5327 0 MTYPE_OSPF6_SPFTREE 60 1024 1056 0 MTYPE_OSPF6_NEXTHOP 32 5134 8192 0 MTYPE_OSPF6_EXTERNAL_INFO 52 0 1024 0 MTYPE_THREAD 68 14703 15192 0 MTYPE_OSPF6_LINK_LIST 44 6849444 7050698 0 MTYPE_OSPF6_LINK_NODE 28 170996 265654 0 MTYPE_OSPF6_LSA_RETRANSMI 20 0 25598 0 Global Memory Pool Usage for all instances : 415468328 bytes global Heap memory for all instances Memory Type Size Allocated Max-alloc Alloc-Fails MTYPE_OSPF6_TOP 41104 1024 1024 0 MTYPE_OSPF6_LSA_HDR 416 76787 107723 0 MTYPE_OSPF6_RMAP_COMPILED 0 0 0 0 MTYPE_OSPF6_OTHER 96 132591 137421 0 MTYPE_THREAD_MASTER 200 1024 1024 0 --------------------- Packet Tx thread Info --------------------- Queue Id[0]: Enqueued[291763] Dequeued [291763] Queue Id[1]: Enqueued[13108] Dequeued [13108] Send Failed Packets - 0 device#
device# show ipv6 ospf area 0
Area 0:
  Authentication: Not Configured
  Active interface(s)attached to this area: Eth 0/1
  Inactive interface(s)attached to this area: None
  Number of Area scoped LSAs is 6
  Sum of Area LSAs Checksum is 000370d3
  Statistics of Area 0:
    SPF algorithm executed 7 times
    SPF last updated: 145 sec ago
    Current SPF node count: 3
      Router: 2 Network: 1
      Maximum of Hop count to nodes: 2
		  device# show ipv6 ospf interface brief Interface Area Status Type Cost State Nbrs(F/C) Eth 0/1 0 up BCST 1 DR 1/1 Lo 1 1 up BCST 1 Loopback 0/0 Lo 2 2 up BCST 1 Loopback 0/0
device# show ipv6 ospf virtual-neighbor
Index Router ID        Address                       State     Interface
1     192.168.0.2      2018:6::5                     Full      Eth 0/1
                Option: 00-00-00    QCount: 0    Timer: 578
device# show ipv6 ospf virtual-links
Transit Area ID  Router ID        Interface Address             State
1                192.168.0.2      2018:6::4                     P2P
  Timer intervals(sec) :
    Hello 10, Hello Jitter 10,  Dead 40, Retransmit 5, TransmitDelay 1
  DelayedLSAck:     3 times
  Statistics:
      Type     tx         rx         tx-byte    rx-byte
      Unknown  0          0          0          0
      Hello    9          9          356        360
      DbDesc   3          2          104        136
      LSReq    1          1          64         28
      LSUpdate 8          7          600        784
      LSAck    7          5          312        240
      OSPF messages dropped,no authentication: 0
  Neighbor: State: Full Address: 2018:6::5 Interface: Eth 0/1
device# show ipv6 ospf database type-7
LSA Key - Rtr:Router Net:Network Inap:InterPrefix Inar:InterRouter
          Extn:ASExternal Grp:GroupMembership Typ7:Type7 Link:Link
          Iap:IntraPrefix Grc:Grace
Area ID         Type LSID       Adv Rtr         Seq(Hex) Age  Cksum Len   Sync
2               Typ7 1          192.168.0.1     80000002 211  f5fd  44    Yes
     Bits: EF-
     Metric: 10
     Prefix Options:
     Referenced LSType: 0
     Prefix: ::/0
     Forwarding-Address: 4321::56
2               Typ7 2          192.168.0.1     80000001 143  a5b2  60    Yes
     Bits: EF-
     Metric: 1
     Prefix Options:
     Prefix: 9876::5/128
device# show ipv6 ospf routes
  Current Route count: 3
    Intra: 3 Inter: 0 External: 0 (Type1 0/Type2 0)
    Equal-cost multi-path: 0
    OSPF Type: IA- Intra, OA - Inter, E1 - External Type1, E2 - External Type2
   Destination                    Cost       E2Cost     Tag        Flags    Dis
IA 1234::56/128                   0          0          0          00000002 110
   Next_Hop_Router                Outgoing_Interface Adv_Router
   ::                             Lo 1               192.168.0.1
IA 2018:6::/64                    1          0          0          00000003 110
   ::                             Eth 0/1            192.168.0.1
IA 4321::56/128                   0          0          0          00000002 110
   ::                             Lo 2               192.168.0.1
device# show ipv6 ospf database as-external
N/A             Extn 2          192.168.0.1     80000001 221  d72f  44    Yes
     Bits: E--
     Metric: 1
     Prefix Options:
     Prefix: 9876::5/128
0               Link 2          192.168.0.1     80000001 790  8399  56    Yes
0               Link 2          192.168.0.2     80000001 652  e939  56    Yes
0               Rtr  0          192.168.0.1     80000003 309  2b16  40    Yes
0               Rtr  0          192.168.0.2     80000002 649  1e26  40    Yes
0               Net  2          192.168.0.1     80000001 648  eafb  32    Yes
0               Inap 1          192.168.0.1     80000001 790  2d79  44    Yes
0               Inap 10         192.168.0.1     80000001 309  0b74  44    Yes
0               Iap  60         192.168.0.1     80000001 648  96dd  44    Yes
1               Rtr  0          192.168.0.1     80000002 309  23a0  24    Yes
1               Inap 4          192.168.0.1     80000001 790  1c2d  36    Yes
1               Inap 11         192.168.0.1     80000001 309  017d  44    Yes
1               Iap  0          192.168.0.1     80000002 1233 e227  52    Yes
2               Rtr  0          192.168.0.1     80000001 309  4975  24    Yes
2               Inap 7          192.168.0.1     80000001 309  f0af  44    Yes
2               Inap 9          192.168.0.1     80000001 309  e95a  36    Yes
2               Typ7 1          192.168.0.1     80000002 309  f5fd  44    Yes
2               Typ7 2          192.168.0.1     80000001 241  a5b2  60    Yes
2               Iap  0          192.168.0.1     80000001 309  0ede  52    Yes
N/A             Extn 2          192.168.0.1     80000001 241  d72f  44    Yes
device# show ipv6 ospf spf tree
SPF tree for Area 0
+- 192.168.0.1 cost 0
     +- 192.168.0.1:2(N) cost 1
         +- 192.168.0.2:0 cost 1
SPF tree for Area 1
SPF tree for Area 2
		  device# show ipv6 ospf spf table SPF table for Area 0 Destination Bits Options Cost Nexthop Interface R 192.168.0.2 ----- V6E---R-- 1 fe80::629c:9fff:fe5a:8919 Eth 0/1 N 192.168.0.1[2] ----- V6E---R-- 1 :: Eth 0/1 SPF table for Area 1 Destination Bits Options Cost Nexthop Interface SPF table for Area 2 Destination Bits Options Cost Nexthop Interface
device# show ipv6 ospf redistribute route Id Prefix Protocol Metric Type Metric 2 9876::5/128 Static Type-2 1
device# show ipv6 ospf routes 1234::56/128 Destination Cost E2Cost Tag Flags Dis IA 1234::56/128 0 0 0 00000002 110 Next_Hop_Router Outgoing_Interface Adv_Router :: Lo 1 192.168.0.1
