DHCP option 82 is a security feature that enables the relay agent to prevent DHCP client requests from untrusted sources.
For more information, see DHCPv4 Relay Agent Option 82.
  1. Access global configuration mode.
    device# configure
  2. Enable option 82.
    device(config)# ip dhcp relay information option
