BGP distributes flow specification (flowspec) rules by using a flow specification Network Layer Reachability Information (NRLI) type.
A BGP application is identified by a specific AFI-SAFI pair. Non-VPN IPv4 BGP flowspec has the following AFI-SAFI pair:
The flow specification NRLI type consists of several optional sub-component types. These sub-component types form the n-tuple of the matching criteria. A specific packet is considered to match the flow specification when it matches the components types in the specification. You can define the following sub-component types or tuples.
Table 1. BGP flowspec NLRI sub-component types
BGP flowspec NLRI type
Description
Encoding
Type 1
Destination Prefix
<type (1 octet), prefix length (1 octet), prefix>
Type 2
Source Prefix
<type (1 octet), prefix-length (1 octet), prefix>
Type 3
IP Protocol (IPv4)
<type (1 octet), [op, value]+>
Type 4
Port
Type 5
Destination port
Type 6
Source port
Type 7
ICMP type
Type 8
ICMP code
Type 9
TCP flags (CWR, ECE, URG, ACK, PSH, RST, SYN, FIN)
<type (1 octet), [op, bitmask]+>
Type 10
Packet length
Type 11
DSCP
Type 12
Fragment (LF, FF, IsF, DF)
