Graceful restart helper is enabled by default when you start OSPFv3. You can disable and re-enable it.
  1. Access global configuration mode.
    device# configure terminal
  2. Enter IPv6 OSPF router configuration mode.
    device(config)# ipv6 router ospf
  3. To disable graceful restart helper, run the following command.
    device(config-ipv6-router-ospf-vrf-default-vrf)# no graceful-restart helper
  4. To re-enable graceful restart, run the following command.
    device(config-ipv6-router-ospf-vrf-default-vrf)# graceful-restart helper
