Four-byte autonomous system numbers (ASNs) can be configured for a neighbor or peer-group. The following task enables 4-byte autonomous system number (ASN) capability for a BGP4+ neighbor.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router bgp command to enable BGP routing.
    device(config)# router bgp
  3. Enter the local-as command to configure the autonomous system number (ASN) in which your device resides.
    device(config-bgp-router)# local-as 1000
  4. Enter the neighbor capability as4 command with the enable parameter, and specify an IPv6 address, to enable 4-byte autonomous system number (ASN) capability for a specific neighbor.
    device(config-bgp-router)# neighbor 2001:db8:93e8:cc00::1 capability as4 enable
The following example enables 4-byte autonomous system number (ASN) capability for a specific BGP4+ neighbor.
