You can define the trusted and untrusted interfaces under Dynamic ARP Inspection (DAI).
An interface is untrusted by default.
  1. Access global configuration mode.
    device# configure terminal
  2. Access interface configuration mode.
    device(config)# interface ethernet 2/3
  3. To define an interface as trusted, run the ip arp inspection trust command.
    device(conf-if-eth-2/3)# ip arp inspection trust
  4. To define a trusted interface as untrusted, run the no ip arp inspection trust command.
    device(conf-if-eth-2/3)# no ip arp inspection trust
The following example defines a port-channel interface as trusted.
device(config)# interface port-channel 200
device(config-Port-channel-200)# ip arp inspection trust
The following example defines a port-channel interface as untrusted.
device(config-Port-channel-200)# no ip arp inspection trust
