You can assign primary and secondary IPv6 addresses to interfaces, using Classless Interdomain Routing (CIDR) network masks.
Configuration of IPv6 addresses on an interface has the following conditions.
  • Multiple primary IPv6 addresses from different subnets are allowed, but not from the same subnet.
  • Secondary IPv6 addresses have the same subnet as the primary addresses.
  • Primary IPv6 addresses cannot be deleted when a secondary address is configured.
  • Secondary IPv6 addresses cannot be added when the primary address is not configured.
Take the following steps to assign IPv6 addresses. The examples in steps 2-5 are for an Ethernet interface.
  1. From privileged EXEC mode, enter global configuration mode.
    device# configure terminal
  2. Access the interface to which you are assigning the IP addresses.
    device(config)# interface ethernet 0/2
  3. Assign one or more primary IP addresses, including the CIDR network mask.
    device(config-if-eth-0/2)# ipv6 address 102:102::1/64
    device(config-if-eth-0/2)# ipv6 address 202:102::1/64
  4. Assign one or more secondary IP addresses, including the CIDR network mask and the secondary keyword.
    device(config-if-eth-0/2)# ipv6 address 102:102::2/64 secondary
    device(config-if-eth-0/2)# ipv6 address 202:102::2/64 secondary
  5. Activate the interface.
    device(config-if-eth-0/2)# no shutdown
