Enabling IPv6 IS-IS globally
When IS-IS is enabled on a device, the device enters IS-IS router configuration mode. Several commands can then be accessed that allow the configuration of IS-IS.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
    ISIS: Please configure NET!
  3. Enter the net command and specify a NSAP address to configure a NET for IS-IS.
    device(config-isis-router)# net 49.2211.0000.00bb.cccc.00
The following example enables IPv6 IS-IS on a device.
