In a data center fabric, you can
suppress Neighbor Discovery (ND) to help reduce ND control traffic.
ND suppression is supported on VLANs
and bridge domains.
By default, ND is not suppressed, which
can lead to excess control traffic.
- A device needs to forward traffic to an IP
address, but the corresponding MAC address is not in its ND cache.
- The device broadcasts an ND request
throughout the IP fabric.
When ND is suppressed, excess control
traffic is reduced.
IP address, but the corresponding MAC address is not in its ND cache.
- The device broadcasts an ND request.
- The leaf BGP EVPN control plane
intercepts the request and looks for a match in its local cache.
- If there is a match, the
control plane responds only to the device.
- If there is no match, the leaf
control plane broadcasts the request to the entire IP fabric.
Tip
When the static anycast
gateway feature is enabled in an IP fabric, suppress ND on the respective VLANs or BDs
to prevent ND broadcast across the network.
