You can change the administrative distance for IPv4 IS-IS routes. The following task changes the administrative distance for the IPv4 IS-IS unicast address family.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
  3. Enter the address-family ipv4 unicast command to enable ISIS address-family IPv4 unicast configuration mode.
    device(config-isis-router)# address-family ipv4 unicast
  4. Enter the distance command and specify a value to change the administrative distance for the IPv4 IS-IS unicast address family.
    device(config-router-isis-ipv4u)# distance 60
The following example sets an administrative distance of 60 for the IPv4 unicast address family.
