Implementing ARP Guard requires creating ARP ACLs, then applying and enabling them on interfaces and port-channels.
Follow these guidelines when implementing ARP Guard.
The following table indicates which hardware profiles support the various types of ARP Guard implementation. For more information, see the show hardware profile command in Extreme SLX-OS Command Reference.
Table 1. Profile Support for ARP Guard
Profile
Basic ARP Guard
ARP Guard with Rate Limiting
ARP Guard on VPLS Endpoint
ARP Guard on VPLS End- point with Rate Limiting
default
Yes
Yes
Yes
Yes
vxlan-visibility
Yes
No
No
No
