In non-default VRF instances, BFD for
		OSPFv2 can be configured globally on interfaces where BFD is enabled.
				Access global configuration
					mode.
					device# configure terminal
				Access OSPF router configuration
					mode and specify the non-default VRF instance.
					device(config)# router ospf vrf red
 This example accesses non-default VRF "red."
				Enable BFD globally.
					device(config-router-ospf-vrf-red)# bfd
				Specify the interval after which
					routes are withdrawn after a BFD session is declared down.
					device(config-router-ospf-vrf-red)# bfd holdover-interval 12
 This example specifies a holdover interval of 12 seconds.
