When BGP4+ is enabled in a non-default VRF instance, the device enters BGP address-family IPv6 unicast VRF configuration mode. From there, you can access several commands that allow the configuration of BGP4+ for the non-default VRF instance.
Before performing this task, ensure that a non-default VRF instance is configured.
  1. Access global configuration mode.
    device# configure terminal
  2. Access BGP configuration mode.
    device(config)# router bgp
  3. Specify the VRF name and enter BGP address-family IPv6 unicast VRF configuration mode.
    device(config-bgp-router)# address-family ipv6 unicast vrf green
    This example shows the address-family ipv6 unicast command, the vrf keyword, and the VRF name (green).
The following example summarizes the commands in this procedure.
device(config-bgp-ipv6u-vrf)#
