IP addresses can be assigned to an Ethernet interface, using Classless Interdomain Routing (CIDR) network masks.
  1. From privileged EXEC mode, access global configuration mode.
    device# configure terminal
  2. Access the interface to which you are assigning the IP addresses.
    device(config)# interface ethernet 0/1
  3. Assign one or more IP addresses, with a CIDR network mask.
    device(config-if-eth-0/1)# ip address 11.1.1.11/24
    device(config-if-eth-0/1)# ip address 11.11.1.11/24
  4. To assign a secondary IP address, include the secondary keyword.
    device(config-if-eth-0/1)# ip address 10.53.5.4/24 secondary
    You can configure a secondary IP address only if the primary IP address is already configured in the same subnet.
  5. Activate the interface.
    device(config-if-eth-0/1)# no shutdown
  6. Verify that the IP addresses are assigned to the interface.
    device(config-if-eth-0/1)# do show ip interface ethernet 3/14
     Ethernet 3/14 is up protocol is up
     Primary Internet Address is 11.1.1.11/24 broadcast is 11.1.1.255
     Primary Internet Address is 11.11.1.11/24 broadcast is 11.11.1.255
     Secondary Internet Address is 11.11.1.12/24 broadcast is 11.11.1.255
     IP MTU is 1500
     Proxy Arp is Enabled
     ICMP unreachables are always sent
     ICMP mask replies are never sent
     IP fast switching is enabled
     Vrf : default-vrf
