By default, a device does not use a
		default route to resolve a BGP4+ next-hop route.
If the IPv6 route lookup for the BGP4+
			next-hop does not result in a valid Interior Gateway Protocol (IGP) route (including
			static or direct routes), the BGP4+ next-hop is considered to be unreachable and the
			BGP4+ route is not used. You can configure the device to use the default route as a
			valid next hop.
				Access global configuration
					mode.
					device# configure terminal
				Access BGP configuration mode.
					device(config)# router bgp
				Access IPv6 address family
					configuration mode.
					device(config-bgp-router)# address-family ipv6 unicast
				Configure the device to use the
					default route as a valid next hop.
					device(config-bgp-ipv6u)# next-hop-enable-default
		The following example summarizes the commands in
				this procedure.
