This task changes the maximum number of seconds an unrefreshed LSP remains in a device‘s LSP database from the default of 1200 seconds (20 minutes) to 2400 seconds (40 minutes).
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
  3. Enter the max-lsp-lifetime command and specify a value to globally configure the maximum LSP lifetime.
    device(config-isis-router)# max-lsp-lifetime 2400
The following example changes the maximum LSP lifetime to 2400 seconds.
