Command-access rules
Command authorization is defined in terms of rules that you associate with a user-defined role.
Rules define and restrict a role to access modes (read-only or read-write access), and beyond that can define permit or reject on specified command groups or individual commands. You can associate multiple rules with a given user-defined role, but you can associate only one role with any given user account.
The following rule parameters are mandatory:
The following rule parameters are optional:
The following example creates and assigns four rules to a role named "NetworkAdmin".
device(config)# rule 70 action accept operation read-write role NetworkAdmin command configure
device(config)# rule 71 action accept operation read-write role NetworkAdmin command copy running-config
device(config)# rule 72 action accept operation read-write role NetworkAdmin command interface management
device(config)# rule 73 action accept operation read-write role NetworkAdmin command clear logging
Rules cannot be added for commands that are not at the top level of the command hierarchy. For a list of eligible commands, type ? after the command keyword.
