The following tables list commands not supported for TACACS+ accounting.
Command name |
Command Description |
cipherset |
Configures FIPS-compliant secure ciphers for LDAP and SSH. |
copy |
Copies data. |
delete |
Delete a specified file. |
dir |
Displays a directory listing. |
exit |
Exits to the top level and optionally runs a command. |
fips |
Executes FIPS-related operations. |
firmwaredownload |
Downloads firmware. |
help |
Provides help information. |
history |
Configures the size of the history log. |
logout |
Terminates the current login session. |
ping |
Executes the ping command. |
quit |
Terminates the current session. |
rename |
Renames a file. |
reload |
Reboots the system. |
show cipherset |
Displays ciphers for LDAP and SSH. |
show cli |
Displays CLI session parameters. |
show file |
Displays the contents of a file. |
show history |
Displays command history. |
show netconf-state |
Displays NETCONF statistics. |
show parser dump |
Displays a parser dump. |
show running-config |
Displays the running configuration. |
show startup-db |
Displays the startup configuration. |
show startup-config |
Displays the contents of the startup-configuration file. |
terminal |
Configures terminal properties. |
traceroute |
Executes the traceroute command. |
Command name |
abort |
Aborts the current configuration session. |
end |
Terminates the current configuration session. |
exit |
Exits from the current mode. |
help |
service |
Performs password encryption services. |
top |
